A carefully selected set of metric sized, stainless steel guide bushes for carrying out many of your template routing requirements. These American-style threaded guide bushes offer excellent accuracy and will fit most UK routers with the addition of a threaded guide bush adaptor. Just select the correct adaptor for your router and enjoy the precision and accuracy of this great set. Each guide bush is marked for easy identification and are presented in a mini tanos systainer, with foam cut out for easy storage. They will also fit many router table insert plates that have a stepped central hole to accommodate them. Set includes 10, 12, 14, 16, 18, 20, 24 and 30mm guide bushes, plus locking ring, two centring shafts (metric & imperial) with centring cone and a 3mm hex key, all neatly supplied in a foam lined mini tanos systainer.
N.B. May require a threaded guide bush adaptor to fit your router.
Made in Britain Yes
Intended Use Fixes to the router base and acts like a ring fence.
Web Attribute Set Router Guide Bushes
EAN Barcode 5052511132935
