{"product_id":"ujk-straight-router-cutters-1-2-shank","title":"UJK Straight Router Cutters 1\/2\" Shank","description":"\u003cp\u003eRouter cutters like you haven’t experienced before. The British Made UJK Router Cutters are built with the traditions of woodworking in mind, with innovative solutions for the modern woodworker.  The new features ensure your routing is safer, cleaner, and lasts longer.\u003c\/p\u003e\u003cp\u003eDesigned, developed and manufactured in Britain, its robust construction is crafted from EN8 steel, ensuring durability and resilience for a strong router cutter. The Xylan coating enhances performance by minimising friction, reducing resin buildup and aiding chip flow, therefore reducing heat. Creating a safer routing environment and enhancing wear resistance, adding longevity to the cutter. Whether you’re a seasoned professional or a hobbyist, these cutters will withstand the test of time.\u003c\/p\u003e\u003cp\u003eThe inclusion of a 'stop insertion ring' eliminates the need to search for faded K lines, ensuring the safe \u0026amp; correct cutter insertion every time, as well as saving valuable time during fitting. Plus, it also acts as a rubber collet seal to prevent wood dust from entering the collet slots.\u003c\/p\u003e\u003cp\u003eThe enhanced shank length offers extended reach for contemporary workshops equipped with router jigs and tables. A high-grade micro carbide ground tip allows for superior plunging performance – all cutting tips on this are micrograin carbide, giving longevity to the cutting performance.\u003c\/p\u003e\u003cp\u003eThe UJK straight cut router cutter is a great all-rounder. Create grooves, channels, cut rebates, and make straight cuts. It’s equally useful for trimming and planning applications, with compatibility across various materials: man-made boards, plywood, chipboard, faced materials, natural timbers, hardwood, and softwood and kitchen worktops.\u003c\/p\u003e\u003cp\u003eProudly made in Britain, the UJK Router Cutters embody quality and precision.\u003c\/p\u003e","brand":"UJK","offers":[{"title":"12.7 mm (1\/2\") \/ 50 mm \/ 1","offer_id":54165141193051,"sku":"111659","price":22.98,"currency_code":"GBP","in_stock":true},{"title":"12.7 mm (1\/2\") \/ 50 mm \/ 5","offer_id":54165141225819,"sku":"111660","price":111.98,"currency_code":"GBP","in_stock":true},{"title":"12 mm \/ 50 mm \/ 1","offer_id":54165141258587,"sku":"111663","price":22.98,"currency_code":"GBP","in_stock":true},{"title":"12.7 mm (1\/2\") \/ 38 mm (1.1\/2\") \/ 1","offer_id":54165141291355,"sku":"111664","price":19.98,"currency_code":"GBP","in_stock":true},{"title":"12 mm \/ 38 mm (1.1\/2\") \/ 1","offer_id":54165141324123,"sku":"111665","price":19.98,"currency_code":"GBP","in_stock":true},{"title":"12.7 mm (1\/2\") \/ 62 mm \/ 1","offer_id":54165141356891,"sku":"111667","price":24.98,"currency_code":"GBP","in_stock":true},{"title":"12 mm \/ 62 mm \/ 1","offer_id":54165141389659,"sku":"111668","price":24.98,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/111659_xl.jpg?v=1790117750","url":"https:\/\/www.axminstertools.com\/products\/ujk-straight-router-cutters-1-2-shank","provider":"Axminster Tools","version":"1.0","type":"link"}
