This carefully chosen UJK Super Dog Accessory Kit contains the most often used products in the range. Each one of these items is invaluable when cutting on an MFT style bench or a worktop made with the UJK Parf Guide system. When it comes to speed, accuracy and ease of use UJK bench dog System is unrivalled.
The set comprises: 2 x Super Dogs, 6 x Guide Pups, 2 x Dog Rail Clips, 1 x UJK Repeat Stop, 8 x UJK Worktop Anti Slip Protectors, 1 x Chamfer Tool and 2 x 20mm Dog Stop Collars. All neatly stored and organised securely in a T-LOC Systainer case. Dogs are CNC machined from 303 stainless steel so they are very durable and less prone to wear.
Case dimensions: 396mm long x 296mm wide.
The UJK Chamfer Ring© is the intellectual property of Axminster Tools Ltd. Any infringement is strictly prohibited.
Made in Britain Yes
Intended Use Used with dog holes to secure your guide rail to the workbench.
EAN Barcode 5052511123919
