UJK
UJK T-Loc Case & Foam Cutout For Work Holding Accessories
SKU: 106535
£113.18
£94.32 Excl. VAT
  • For UJK cutting and clamping accessories
  • Empty T-LOC case and foam insert with cutouts
  • T-LOC case provides secure and neat storage
  • Dimensions: 396mm long x 296mm wide
Keep your UJK cutting and clamping accessories securely and neatly stored, when not in use. This is an empty T-LOC case with a foam insert. The insert has cutouts for UJK Cam Clamps, Wedges, Back Stops, Dog Rail Clips, Guide Pups, Guide Dogs and the Chamfer Tool. Dimensions: 396mm long x 296mm wide. Please note: this is the same case as supplied with the UJK Work Holding Accessory Kit.
Intended Use Storage case for use with the UJK Parf Dog accessoires.
Web Attribute Set Organiser Cases
EAN Barcode 5052511119288
