The UJK Router Cutter T-LOC Case offers a smart, secure solution for storing and transporting your router cutters. Whether you're working on-site or organising your workshop, this case ensures your valued cutters remain well-protected, neatly arranged and instantly accessible.
Housed in a robust UJK T-LOC case, the custom-cut foam insert is precision-engineered to securely hold a wide range of router cutter sizes. Each slot or hole provides a snug fit, minimising movement and protecting the sharp edges from damage.
There are 10 horizontal slots designed to store 12mm or 1/2 shank router cutters with cutting lengths of up to 60mm, 25 vertical holes for 12mm or 1/2 shank cutters, 25 vertical holes for 8mm shank cutters and 25 vertical holes for 1/4 shank cutters.
British made, this case is tough enough for site or workshop use. Like all UJK T-LOC cases, it’s fully stackable and compatible with the wider system, locking securely with the single-handed T-LOC catch.
Overall L x W x H 390mm x 295mm x 115mm
Web Attribute Set Organiser Cases
EAN Barcode 5052511143450
