This pair of UJK Telescopic Trestles is designed to deliver strength, precision, and versatility in equal measure. Whether you’re using them to support the UJK Multifunction Workbench Mk II or as a robust standalone setup, these trestles are built to perform. Manufactured from durable steel for long‑term reliability, each trestle offers exceptional rigidity, while the top rails provide an ideal surface for accurate side clamping.
A smooth telescopic height adjustment mechanism and positive locking system make it quick and easy to set your preferred working height. The wide footprints, complete with rubber feet, ensure superb stability on workshop floors, job sites, or outdoor surfaces. Each trestle includes a lower rail for convenient tool storage, keeping essential items close to hand as you work.
Fully compatible with the UJK Multifunction Workbench Mk II, this pair of Telescopic Trestles brings premium workshop functionality to your workspace - strong, stable, and exceptionally well made.
Specifications (per trestle)
Height range: 780–1,190 mm
Footprint: 660 × 685 mm
Maximum load: 200 kg
Overall L x W x H 660mm x 685mm x 1,190mm
Web Attribute Set Portable Work Benches & Trestles
EAN Barcode 5052511146543
