UJK Threaded Guide Bushes are British made and manufactured from stainless steel. Sold in individual sizes from 10mm UJK Threaded Guide Bushes to 30mm UJK Threaded Guide Bushes. The American threaded-style metric guide bushes deliver exceptional accuracy and durability. Designed to fit most UK routers with the use of a threaded guide bush adaptor, they’re ideal for precision routing tasks. Each bush is clearly marked for easy identification and is compatible with many router table insert plates featuring a stepped central hole. Available individually in, 10mm, 12mm, 14mm, 16mm, 18mm, 20mm, 24mm, and 30mm, so you can choose exactly what you need for your project.
Note: A threaded guide bush adaptor may be required to fit your router.
Outer Diameter 10 mm
Web Attribute Set Router Guide Bushes
EAN Barcode 5052511142743
