The UJK Track Saw Set, is the perfect companion for precision cutting without confusion.
Whether you're using the UJK Parf Guide System or an MFT table, the UJK Track Saw Set contains the all essential UJK accessories required to achieve the highest accuracy of your cuts.
Your workpiece will always be square with the UJK Track Saw Set. The set includes a pair of UJK 60mm expanding dogs and UJK 12mm guide dogs, designed for precision squaring, while the UJK Dog Stop Collars and UJK Rail Clips provide stability, eliminating rocking and maintaining that stability throughout your cuts. Cutting into your worksurface will also be a thing of the past. With the UJK Track Saw Set, you can make precise cuts without leaving a mark.
Made in Axminster, UK, the set includes carefully selected UJK products listed below, all neatly organised in a tough storage case for ease of use.
