The UJK Hex Shank Adaptor Ultimate Drill Bit Kit combines three of UJK’s finest drilling solutions into one versatile set: the UJK Hex Shank Drill Bit Adaptor, the UJK StepPower HSCO Drill Bits, and UJK M2 HSS Premium Brad Point Drill Bits for selected sizes. Together, they give you the speed and convenience of quick-change adaptors, the durability and cutting power of cobalt drill bits for metal and hardwood, and the accuracy of precision-ground brad point bits for clean woodworking. Whether you’re working in timber, engineered boards, acrylics, or metal, this kit ensures you always have the right bit ready to deliver accurate, efficient results.
Transform your standard round shank drill bits, burrs, and abrasive points into quick-change hex shank tools with the UJK Hex Shank Drill Bit Adaptor. Compatible with standard 1/4
Engineered for performance, the UJK StepPower HSCO Drill Bits are crafted from 5% cobalt high-speed steel for maximum wear resistance and durability. Their unique multi-step design, combined with a 118° point geometry, ensures perfect centring, clean entry, and reduced splintering. While primarily designed for metalworking, their sharpness and precision make them equally effective in hardwoods. A 3-flat shank prevents slipping in the chuck, guaranteeing accuracy and efficiency whether you’re drilling in metal, wood, or both.
Made in Austria to exacting standards, these M2 HSS Premium Brad Point Drill Bits are optimised for hardwoods but equally capable in softwoods, laminated boards, MDF, and even acrylic glass. Featuring a CNC-machined centre point for precise starts, two raised spurs (0.4mm higher) for splinter-free edges, and a four-flute spiral design for faster chip clearance, they deliver exceptional accuracy and finish. Manufactured from high-grade M2 HSS steel, they offer long-lasting durability and consistent performance across a wide range of materials.
