{"product_id":"ujk-universal-dovetail-jig","title":"UJK Universal Dovetail Jig","description":"\u003cp\u003eUJK are proud to introduce the Universal Dovetail Jig; made and developed in the UK. Straight out of the box it gives you the possibility of producing six different joints, with unrivalled accuracy.\u003c\/p\u003e\u003cp\u003eUJK Universal Dovetail Jig can produce:\u003c\/p\u003e\u003cp\u003e1. Half blind dovetails\u003c\/p\u003e\u003cp\u003e2. Box\/ finger joints\u003c\/p\u003e\u003cp\u003e3. Through dovetails\u003c\/p\u003e\u003cp\u003e4. Sliding dovetails\u003c\/p\u003e\u003cp\u003e5. Groove\/ housing joints\u003c\/p\u003e\u003cp\u003e6. Corner dovetail rebates\u003c\/p\u003e\u003cp\u003eThe base of this jig is a heavy gauge steel pressing with other parts precisely CNC machined; a combination of accuracy and strength. The super hard anodised finish on the finger templates ensure long term accuracy. The jig features a stabiliser bar located in front of the comb, which provides a much greater surface area to support your router’s base.\u003c\/p\u003e\u003cp\u003eThe UJK Universal Dovetail Jig also incorporates a greatly improved dust extraction outlet. Held in place by a strong magnetic strip, the outlet is easily detached when loading workpieces in your jig.\u003c\/p\u003e\u003cp\u003eSet-up and use is simple. An 11mm offset at each end of the template greatly speeds up initial marking. Fast cam action clamps, hold your workpieces quickly and securely.\u003c\/p\u003e\u003cp\u003eThe jig can be used with any router that will take 1\/4\u003cspecial id=\"1\"\u003e\u003c\/special\u003e, 8mm or 1\/2\u003cspecial id=\"1\"\u003e\u003c\/special\u003e shank cutters. The jig comes with three 1\/4\u003cspecial id=\"1\"\u003e\u003c\/special\u003e shank Axcaliber precision ground TCT router cutters; A matched pair for dovetailing (7 degree dovetail and straight) and a 12.5mm straight cutter. Also included are two American style threaded guide bushes and full instructions.\u003c\/p\u003e\u003cp\u003eMaterial capacity: 300mm width, 6–25mm dovetail thickness.\u003c\/p\u003e\u003cp\u003eAn additional UJK guide bush adaptor to suit your router should be purchased separately. An 8mm- 1\/4\u003cspecial id=\"32\"\u003e\u003c\/special\u003e sleeve is also supplied.\u003c\/p\u003e","brand":"UJK","offers":[{"title":"Default Title","offer_id":54118397575515,"sku":"106843","price":435.0,"currency_code":"EUR","in_stock":false}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/106843_xl.jpg?v=1789778506","url":"https:\/\/www.axminstertools.com\/products\/ujk-universal-dovetail-jig","provider":"Axminster Tools","version":"1.0","type":"link"}
