UJK
UJK Universal Sub-Base & Fixing Kit
SKU: 718650
£55.58
£46.32 Excl. VAT
  • Aluminium sub-base with low friction surface
  • Suitable for a wide variety of routers
  • Accepts standard UJK guide bushes
  • Fixing kit is included • Use supplied centre pins to centre cutter onto wood
Some routers can be difficult to match up with suitable guide bushes and a universal sub-base can be the only solution. A round base can be preferable in many circumstances too. The UJK sub-base is precision machined from aluminium and fitted with a low friction surface for ease of use. It is designed to accept standard UJK guide bushes and holes for these are drilled with an M4 thread. It is also designed for mounting to a very wide range of different routers including Bosch, Makita, Elu, Dewalt, Festool, Trend, Ryobi and Hitachi models to name a few and a fixing kit is included to cover a variety of thread types. 176mm diameter x 7mm thickness.
Web Attribute Set Router Jigs & Templates
EAN Barcode 5052511039616
