The UJK Spiral Cutter (1/2) is British made from solid tungsten carbide, delivering fast, controlled routing with a consistently clean, precise finish. Engineered for performance, the upcut spiral flute geometry creates a shearing cutting action that produces smoother results than standard straight cutters, while efficiently drawing chips and dust away from the cut. This improves cooling, reduces heat build-up and helps maintain cutter sharpness, particularly during demanding applications such as deep cutting, mortising and rapid material removal.
The upward cutting action pulls the router down towards the workpiece, providing improved control and stability, making these cutters especially effective for guided routing and template work. Designed to work seamlessly with UJK Loose Tenon Cutters, each size is carefully matched to deliver accurate, repeatable mortises for strong, reliable joinery. With smoother, quieter operation and reduced vibration, these cutters minimise strain on both the user and the router, ensuring greater confidence and performance across a wide range of materials.
Available in 1/2 shank sizes including 8mm x 27mm, 10mm x 32mm and 12mm x 52mm, offering flexibility for deeper cuts and more demanding routing applications in hardwood, softwood and sheet materials.
X = Depth of Cut 27 mm (1.1/16")
D = Overall Diameter 8 mm (5/16")
Web Attribute Set Spiral Router Cutters D: 8 X: 27
EAN Barcode 5052511145508
