{"product_id":"ujk-variable-angle-kitchen-worktop-jig","title":"UJK Variable Angle Kitchen Worktop Jig","description":"\u003cp\u003eThis one jig can offer so much scope. It is capable of 45\u003cspecial id=\"8\"\u003e\u003c\/special\u003e and 90\u003cspecial id=\"8\"\u003e\u003c\/special\u003e left or right hand joints in  worktops with widths of 250\/300\/400\/450\/500\/550\/600\/616\/620\/650\/700mm. It enables you to make peninsular joints, corner radii of 40mm, 100mm, 90\u003cspecial id=\"8\"\u003e\u003c\/special\u003e square end cuts plus 45\u003cspecial id=\"8\"\u003e\u003c\/special\u003e and 22.5\u003cspecial id=\"8\"\u003e\u003c\/special\u003e angle cuts. In addition, there are facilities for cutting 35mm cabinet door hinge recesses (18mm carcass), a hole for tap fixings 35mm (3\/4\u003cspecial id=\"1\"\u003e\u003c\/special\u003e BSP) and three slots for 65mm and 150mm joining bolts. There is also an extra hole for 635mm width of worktops included in the jig. The jig is CNC cut from 12mm thick solid compact phenolic resin which is very stable and doesn't warp. Permanently engraved into the top are instructions, diagrams and pin-hole locations.\u003c\/p\u003e\u003cp\u003eThis professional patented kitchen worktop jig is also able to solve problems regarding out of square joints. With the addition of the optional accessory, the Angle Adjustment Plate, (sold separately) the jig will cut accurate left and right hand joints between 85\u003cspecial id=\"8\"\u003e\u003c\/special\u003e and 95\u003cspecial id=\"8\"\u003e\u003c\/special\u003e. The Angle Adjustment Plate sits in the slot provided and adjustment is made to change the angle of the male joint. With the addition of the Plate you can use the jig to find and set the angle required ensuring a perfect joint every time.\u003c\/p\u003e\u003cp\u003e\u003cspecial id=\"22\"\u003e\u003c\/special\u003eSupplied with full and comprehensive instructions and a pack of 4 aligning pins.\u003cspecial id=\"23\"\u003e\u003c\/special\u003e\u003c\/p\u003e\u003cp\u003eYou will also need 1\/2\u003cspecial id=\"1\"\u003e\u003c\/special\u003e router, 12.7mm(1\/2\u003cspecial id=\"1\"\u003e\u003c\/special\u003e) x 50mm  router cutter, 30mm guide bush and 2 clamps.\u003c\/p\u003e","brand":"UJK","offers":[{"title":"Default Title","offer_id":54117967200603,"sku":"508615","price":108.88,"currency_code":"GBP","in_stock":false}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/508615_xl.jpg?v=1789770889","url":"https:\/\/www.axminstertools.com\/products\/ujk-variable-angle-kitchen-worktop-jig","provider":"Axminster Tools","version":"1.0","type":"link"}
