This Vee block is an optional accessory for the UJK Drill Table and Fence. It simply bolts into the table in place of the sacrificial plate. This block allows you to accurately drill round workpieces. It has a centring hole for accurate placing for the drill bit. A simple and worthwhile accessory. Size 115mm x 100mm.
Web Attribute Set Drilling Machines Tables & Accessories
EAN Barcode 5052511120413
