{"product_id":"veritas-10mm-tapered-snug-plug-cutter-flush-cutting-saw-package-deal","title":"Veritas 10mm Tapered Snug Plug Cutter \u0026 Flush Cutting Saw - PACKAGE DEAL","description":"\u003cp\u003eThe package deal comprises the Veritas 10mm Tapered Snug Plug Cutter and the Veritas Flush Cutting Saw.\u003c\/p\u003e\u003cp\u003eVeritas 10mm Tapered Snug Plug Cutter\u003c\/p\u003e\u003cp\u003eSometimes when plugging holes, no matter how carefully drilled, the holes finish up slightly oversize for the plug, especially in soft woods. These cabinet maker's snug plug cutters overcome this by cutting a slightly tapered plug. The first 3mm of the plug is the diameter stated whilst the remaining length is then flared out at an angle of 3°. Just tap the plug into place until you meet resistance then cut off the excess. Also, unlike regular plug cutters which have two cutting flutes, these plug cutters have four, giving a much cleaner cut and a smooth-sided plug which fits perfectly every time and is practically invisible. For best results use in a drill press or power drill stand.\u003c\/p\u003e\u003cp\u003eVeritas Flush Cutting Saw\u003c\/p\u003e\u003cp\u003eTraditionally used for the rapid trimming of plugs and dowels flush with a surface, these flush cutting saws can be used where you want to cut off a projection without damaging the surrounding or adjoining face. The Japanese tooth pattern blade cuts aggressively (on the pull stroke), but does not mark the surface that it is cutting next to. The thin blade is flexible and can be pressed flush to any surface, yet is rigid enough for good control. The saw has teeth cut on both sides with the teeth set in one direction. 290mm long with 120mm of blade.\u003c\/p\u003e","brand":"Veritas","offers":[{"title":"Default Title","offer_id":54227154469211,"sku":"717718","price":39.98,"currency_code":"GBP","in_stock":false}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/717718_xl.jpg?v=1790850135","url":"https:\/\/www.axminstertools.com\/products\/veritas-10mm-tapered-snug-plug-cutter-flush-cutting-saw-package-deal","provider":"Axminster Tools","version":"1.0","type":"link"}
