The Veritas Bevel-Up Smooth Plane with PM-V11 Blade is a precision-engineered hand plane designed to produce exceptionally smooth finishes, particularly when working with difficult or figured grain. Combining a wide, accurately machined sole with an adjustable mouth and a bevel-up blade configuration, it offers excellent control and versatility for fine woodworking. Its 50° cutting angle helps minimise tear-out, making it particularly useful when achieving clean, smooth surfaces on challenging timber.
Constructed from stress-relieved ductile cast iron, the plane provides excellent rigidity and stability during use. The 12° bed angle combined with the supplied 38° blade bevel produces a 50° cutting angle, helping reduce tear-out when planing difficult grain. The adjustable mouth can be easily repositioned using the front locking knob, while a dedicated stop-screw allows the preferred opening to be set and accurately restored. The hardwood handle and front knob provide comfortable handling, while the precision-engineered adjustment mechanism makes setting the blade straightforward and reliable.
The 254mm (10in) long, 79.4mm (3 1/8in) wide sole is accurately machined flat to provide a stable reference surface across the workpiece. The 57.2mm (2 1/4in) wide, 4.8mm (3/16in) thick PM-V11 blade is lapped on its non-bevelled face to a flatness tolerance of 0.005mm (0.0002in) or better across the working surface. Its average surface roughness is 0.000127mm (0.000005in) or better, supporting accurate and consistent cutting performance. Weighing approximately 2.21kg (4lb 14oz), the plane has a substantial feel that helps maintain stability and control during planing.
Veritas is renowned for producing innovative, precision-engineered woodworking tools in Canada. Combining traditional hand-tool design with modern manufacturing techniques and materials, Veritas has established a reputation for exceptional accuracy, performance and durability amongst professional woodworkers and dedicated enthusiasts.
The Veritas Bevel-Up Smooth Plane is ideal for furniture makers, cabinetmakers and experienced woodworking enthusiasts who regularly work with difficult grain and require a high-quality smoothing plane. Supplied with a premium PM-V11 blade with a 38° bevel, it features a stress-relieved ductile cast iron body, hardwood handle and front knob, finished in distinctive black and brass. Manufactured in Canada.
