{"product_id":"veritas-cabinet-scraper","title":"Veritas Cabinet Scraper","description":"\u003cp\u003eThe Veritas Cabinet Scraper can be used to smooth glue lines or surfaces such as panels and table tops, or where there is tricky grain, without tear out, digs or gouges. The sole is longer and the handles have been placed further back and slightly lower than the No.80 on which it is based. This allows pressure to be applied directly in line with the cutting edge and prevents the blade from catching when the scraper runs off the end of the workpiece. The 70mm(2.3\/4\u003cspecial id=\"1\"\u003e\u003c\/special\u003e) wide blade has both cutting edges ground at 45\u003cspecial id=\"8\"\u003e\u003c\/special\u003e to permit preparation of two edges at once. The 80mm (3.3\/16\u003cspecial id=\"1\"\u003e\u003c\/special\u003e) x 85mm(3.3\/8\u003cspecial id=\"1\"\u003e\u003c\/special\u003e) sole is surface ground for accuracy. The body is made from ductile cast iron, overall length 290mm(11.1\/2\u003cspecial id=\"1\"\u003e\u003c\/special\u003e) weight approximately 740g(1lb.10oz).\u003c\/p\u003e","brand":"Veritas","offers":[{"title":"Default Title","offer_id":54116542284123,"sku":"474843","price":100.28,"currency_code":"GBP","in_stock":false}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/474843_xl.jpg?v=1789761123","url":"https:\/\/www.axminstertools.com\/products\/veritas-cabinet-scraper","provider":"Axminster Tools","version":"1.0","type":"link"}
