{"product_id":"veritas-dovetail-fine-tooth-dovetail-saw-package-deal","title":"Veritas Dovetail \u0026 Fine Tooth Dovetail Saw - PACKAGE DEAL","description":"\u003cp\u003e\u003cspecial id=\"22\"\u003e\u003c\/special\u003ePackage deal comprises the Veritas Dovetail Saw and the Veritas Fine-Tooth Dovetail Saw.\u003cspecial id=\"23\"\u003e\u003c\/special\u003e\u003c\/p\u003e\u003cp\u003e\u003cspecial id=\"22\"\u003e\u003c\/special\u003eVeritas Dovetail Saw\u003cspecial id=\"23\"\u003e\u003c\/special\u003e\u003c\/p\u003e\u003cp\u003eThis innovative saw features a spine that is permanently moulded onto the back of its blade. The spine imparts just the right amount of weight to the blade to carry the saw effortlessly into the cut. When you're performing a task like cutting dovetails, accuracy is paramount. With this saw's weight and design, full control is assured. The polished hardwood handle is shaped to fit the hand comfortably and not just to look pretty, which it also does. In fact the handle is very reminiscent of the rear tote on a bench plane and this theme is carried on in the steel rod that passes right through the handle and the brass nut used to attach the handle to the rod. A mortice and tenon joint between handle and back ensures a good solid and secure fixing between the two parts. The blade is Japanese high carbon steel, 230mm (9\u003cspecial id=\"1\"\u003e\u003c\/special\u003e) long by 40mm (1.1\/2\u003cspecial id=\"1\"\u003e\u003c\/special\u003e) deep, with razor sharp 14tpi teeth filed with a 14\u003cspecial id=\"8\"\u003e\u003c\/special\u003e rake angle, the overall weight is 360g (12.7oz).\u003c\/p\u003e\u003cp\u003e\u003cspecial id=\"22\"\u003e\u003c\/special\u003eVeritas Fine-Tooth Dovetail Saw\u003cspecial id=\"23\"\u003e\u003c\/special\u003e\u003c\/p\u003e\u003cp\u003eFor woodworkers who prefer a fine-tooth dovetail saw, Veritas produce a premium example with a 20 teeth per 25mm (20tpi blade) filed for rip cutting. It has a 235mm (9.1\/4\u003cspecial id=\"1\"\u003e\u003c\/special\u003e) long by 0.5mm thick high-carbon steel blade. The teeth have a rake angle of 14\u003cspecial id=\"8\"\u003e\u003c\/special\u003e, and an included angle of 60\u003cspecial id=\"8\"\u003e\u003c\/special\u003e. The depth of cut is about 40mm (1.9\/16\u003cspecial id=\"1\"\u003e\u003c\/special\u003e).\u003c\/p\u003e\u003cp\u003eThe back of this saw is injection moulded under high pressure onto the blade and stainless-steel handle-mounting bolt. This forms a solid one-piece blade\/spine\/mount assembly. The material used for the back incorporates stainless-steel powder for weight, glass fibre for stiffness, and a polymer resin binder. A brass nut fastener secures the comfortably shaped hardwood handle. The saw has great balance it cuts easily, stays true and the pistol grip helps make the saw feel like an extension of your arm. Overall length 360mm (14.1\/4\u003cspecial id=\"1\"\u003e\u003c\/special\u003e)\u003c\/p\u003e","brand":"Veritas","offers":[{"title":"Default Title","offer_id":54227188253019,"sku":"717452","price":158.98,"currency_code":"GBP","in_stock":false}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/717452_xl.jpg?v=1790850386","url":"https:\/\/www.axminstertools.com\/products\/veritas-dovetail-fine-tooth-dovetail-saw-package-deal","provider":"Axminster Tools","version":"1.0","type":"link"}
