{"product_id":"veritas-medium-shoulder-plane","title":"Veritas Medium Shoulder Plane","description":"\u003cp\u003eThe Veritas Medium Shoulder Plane with PM-V11 Blade is a precision-made hand plane designed for trimming and refining the shoulders and cheeks of joints. Its medium-sized body offers a useful balance of reach and control, making it ideal for fitting tenons, cleaning up rebates and achieving accurate, close-fitting joinery.\u003c\/p\u003e\n\u003cp\u003eThe stress-relieved ductile cast iron body measures 178mm (7in) long and 17.5mm (11\/16in) wide, with the sole and sides accurately machined and ground flat and square. The lever cap features a pivoting knob, allowing you to adjust the plane to suit your hand and preferred holding style. A through-hole in the body provides an additional grip point for improved control during use.\u003c\/p\u003e\n\u003cp\u003eThe adjustable toe allows the mouth opening to be narrowed for very fine shavings and reduced tear-out. The PM-V11 blade is 3.2mm (1\/8in) thick and sits at a 15° bed angle; combined with its 25° bevel, this produces a 40° cutting angle. Side set screws allow accurate blade positioning and make it easy to reinstall the blade after sharpening without needing lateral adjustment. The non-bevel side is lapped to a flatness tolerance of 0.005mm (0.0002in) or better across the working surface, with an average surface roughness of 0.000127mm (0.000005in) or better.\u003c\/p\u003e\n\u003cp\u003eVeritas is renowned for producing high-quality woodworking tools that combine thoughtful design with precise engineering. Manufactured in Canada, its planes are developed to provide accuracy, control and dependable performance in the workshop.\u003c\/p\u003e\n\u003cp\u003eWeighing approximately 907g (2lb), the Veritas Medium Shoulder Plane is ideal for fitting medium-sized tenons, refining joint shoulders, trimming rebates and cleaning up the cheeks of joints. Its longer body provides good control when working along joint surfaces, while the adjustable mouth and accurately positioned blade make it particularly useful for fine fitting in cabinetmaking, furniture making and general joinery.\u003c\/p\u003e","brand":"Veritas","offers":[{"title":"Default Title","offer_id":55271714357595,"sku":"717527","price":350.0,"currency_code":"USD","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/717527_xl.jpg?v=1795440732","url":"https:\/\/www.axminstertools.com\/products\/veritas-medium-shoulder-plane","provider":"Axminster Tools","version":"1.0","type":"link"}
