Veritas
Veritas Miniature Plough Plane
SKU: 104777
£51.95 £54.68 Save £2.73
£43.29 Excl. VAT
  • 1/3 scale, fully working plough plane
  • Perfect miniature copy the Veritas plough plane
  • 75mm long and weighs just 95g
  • Investment-cast, machined steel with wooden tote
  • 2.4mm wide blade with micro adjustment
  • Maximum 4mm depth of cut
  • Supplied in French-fitted embossed leatherette box
  • Made in Canada
The Veritas Miniature Plough Plane is a 1/3 scale, fully working version of the Veritas small plough plane. In this case, the plane is only 75mm long and weighs less than 95g.
Made from investment-cast and machined steel, it has a wooden tote and a 2.4mm wide blade for cutting slots. It has a maximum 4mm depth of cut and up to 11mm of side fence offset. A small cap-head hex screw, clamps the blade in place (a 5/64" hex key is included). As with the full size version, the blade is micro-adjustable.
Made in Canada, it comes in a French-fitted embossed leatherette box.
Plane Sole Length 75 mm
Web Attribute Set Hand Planes
