{"product_id":"veritas-mk-ii-honing-system-and-camber-roller-package-deal","title":"Veritas Mk.II Honing System and Camber Roller - PACKAGE DEAL","description":"\u003cp\u003e\u003cspecial id=\"22\"\u003e\u003c\/special\u003ePackage deal comprises the Veritas Mk.II Honing System and the Veritas Camber Roller\u003cspecial id=\"23\"\u003e\u003c\/special\u003e\u003c\/p\u003e\u003cp\u003e\u003cspecial id=\"22\"\u003e\u003c\/special\u003eVeritas Mk.II Honing System\u003cspecial id=\"23\"\u003e\u003c\/special\u003e\u003c\/p\u003e\u003cp\u003eThe main feature of the Veritas Mk.II is its blade registration system squaring and setting the blade in one easy step. The Mk.II Guide has three bevel angle range configurations: a high angle (25\u003cspecial id=\"8\"\u003e\u003c\/special\u003e to 54\u003cspecial id=\"8\"\u003e\u003c\/special\u003e in seven increments), standard (15\u003cspecial id=\"8\"\u003e\u003c\/special\u003e to 40\u003cspecial id=\"8\"\u003e\u003c\/special\u003e in six increments), and a third for back bevels. The registration jig slides onto the guide body, centering and squaring the blade using an integral fence. The clamping mechanism registers on the face of the blade and is designed to accept flat and tapered blades, as well as blades with irregular geometry. The Mk.II features a three-position eccentric roller allowing a micro-bevel to be honed quickly and accurately after only a simple turn of a knob. The 50mm wide roller is stable for even the narrowest of blades. The guide can easily accommodate chisels or blades from 12 to 72mm wide and up to 13mm thick including spokeshave blades. \u003cspecial id=\"22\"\u003e\u003c\/special\u003eSharpening stone not included\u003cspecial id=\"23\"\u003e\u003c\/special\u003e\u003c\/p\u003e\u003cp\u003e\u003cspecial id=\"22\"\u003e\u003c\/special\u003eVeritas Camber Roller\u003cspecial id=\"23\"\u003e\u003c\/special\u003e\u003c\/p\u003e\u003cp\u003eThis is an attachment specifically designed for use with the Veritas Mk.II Honing Guide. When planing on large, flat surfaces, it is often desirable to hone a slight curve, or camber, into the edge of the blade. The Veritas Camber Roller Assembly has a barrel-shaped roller that allows limited rocking, whilst still maintaining an accurate and consistent bevel angle. Simply replace the standard roller assembly with the camber assembly and sharpen. The blade is still set using the registration jig, and the camber roller includes the standard eccentric system allowing micro-bevels to be honed.\u003c\/p\u003e","brand":"Veritas","offers":[{"title":"Default Title","offer_id":54227210666331,"sku":"717456","price":87.0,"currency_code":"EUR","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/200810_xl_da2cce94-3dc9-4e01-8c20-575186aa471f.jpg?v=1790850692","url":"https:\/\/www.axminstertools.com\/products\/veritas-mk-ii-honing-system-and-camber-roller-package-deal","provider":"Axminster Tools","version":"1.0","type":"link"}
