{"product_id":"veritas-plunge-base-for-rotary-multi-tools","title":"Veritas Plunge Base for Rotary Multi-Tools","description":"\u003cp\u003eThis plunge base converts almost any rotary multi-tool into a miniature plunge router for fine detail work. The 3\/4\u003cspecial id=\"1\"\u003e\u003c\/special\u003e x 12 tpi  threaded collar, found as standard on Dremel and many other rotary multi-tools, screws directly into the base. It gives you precise depth control when cutting recesses for hardware or inlay, or even freehand relief carving. The 100  x 75mm footprint makes it easy to position on narrow surfaces and close to edges. One side features a cutaway giving a view of the exact position of the blade. A micro-adjustable depth stop offers very precise control over the cutting depth. As with a full size router you can plunge or use the lock lever for continuous cuts. The base has rounded grooves on either side which form a natural grip for your fingertips giving better control.  Made in Canada from aluminium with stainless steel rods and knobs.\u003c\/p\u003e","brand":"Veritas","offers":[{"title":"Default Title","offer_id":54118166364507,"sku":"102163","price":79.0,"currency_code":"EUR","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/102163_xl.jpg?v=1789771737","url":"https:\/\/www.axminstertools.com\/products\/veritas-plunge-base-for-rotary-multi-tools","provider":"Axminster Tools","version":"1.0","type":"link"}
