{"product_id":"veritas-pocket-layout-square-35mm","title":"Veritas Pocket Layout Square 35mm","description":"\u003cp\u003eSmall, neat and much more useful than merely handy. This square has some of the functionality of a larger rafter square. The difference being, you can pop this into your apron pocket. It’s always on hand, when it comes to laying out small joints where a full size square is just too clumsy. Another advantage of the reduced size is its usefulness in checking squareness on confined spaces or that of a blade to a table on a scroll saw for example.\u003c\/p\u003e\u003cp\u003eThe square is machined from a solid aluminium extrusion, anodized and laser etched on both sides. The vertical edge is graduated in millimetres. The hypotenuse features angle graduations, marked every 10\u003cspecial id=\"8\"\u003e\u003c\/special\u003e. Pivoting the square against the edge of the work and rotating it to your chosen angle, is a quick and easy method of marking angles on small workpieces.\u003c\/p\u003e\u003cp\u003eThe base on the 35mm pocket layout square is 12.7 mm wide. The base has an offset of 3.2mm on one side and 6.35mm on the other.\u003c\/p\u003e","brand":"Veritas","offers":[{"title":"Default Title","offer_id":54118482837851,"sku":"109383","price":8.28,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/109383_xl.jpg?v=1789781975","url":"https:\/\/www.axminstertools.com\/products\/veritas-pocket-layout-square-35mm","provider":"Axminster Tools","version":"1.0","type":"link"}
