In use the roller of Veritas MkII honing guide is exposed to water and abrasive particles. The fine particles can get between the roller and the cam, causing wear and eventually spoiling the smooth running.
This replacement straight roller assembly for the Veritas MkII honing guide will restore your honing guide to peak performance.
Web Attribute Set Honing Guides
EAN Barcode 5052511121120
