{"product_id":"veritas-side-rebate-plane","title":"Veritas Side Rebate Plane","description":"\u003cp\u003eThe Side Rebate Plane is used for cleaning up or trimming sidewalls of rebates, dados or grooves. It has a practical dual-blade configuration, coupled with an ingenious pivoting sculpted to fit comfortably handle that permits right or left-hand use to accommodate grain direction. The thin sole functions much like a skate, allowing use in slots as narrow as 4.8mm(3\/16\u003cspecial id=\"1\"\u003e\u003c\/special\u003e) and to a depth of 12.7mm(1\/2\u003cspecial id=\"1\"\u003e\u003c\/special\u003e). The toe is removable for use in stopped dados and has a fixing screw that is trapped to prevent loss. The depth stop helps orient and stabilise the plane during use and is both height adjustable and reversible. The accurately machined, 115mm(4-1\/2\u003cspecial id=\"1\"\u003e\u003c\/special\u003e) long ductile cast iron plane body and the two O1 tool steel blades (HRC 58-60) are lapped. The lapped blades have a flatness tolerance of ±0.005mm or better over the working surface, and with an average roughness surface finish of 0.000127mm(5 microinches) or better. Weight 450g. Made in Canada.\u003c\/p\u003e","brand":"Veritas","offers":[{"title":"Default Title","offer_id":54116545626459,"sku":"211005","price":164.58,"currency_code":"GBP","in_stock":false}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/211005_xl.jpg?v=1789761281","url":"https:\/\/www.axminstertools.com\/products\/veritas-side-rebate-plane","provider":"Axminster Tools","version":"1.0","type":"link"}
