{"product_id":"veritas-small-crosscut-saw-16tpi-235mm","title":"Veritas Small Crosscut Saw 16tpi - 235mm","description":"\u003cp\u003eThe saw has a 235mm (9.1\/4\u003cspecial id=\"1\"\u003e\u003c\/special\u003e) long by 0.5mm thick high-carbon steel blade filed with 16 teeth per 25mm (16tpi). The teeth have 15\u003cspecial id=\"8\"\u003e\u003c\/special\u003e rake and bevel angles. The depth of cut is about 40mm. The back of this saw is injection moulded under high pressure onto the blade and stainless-steel handle-mounting bolt. This forms a solid one-piece blade\/spine\/mount assembly. The material used for the back incorporates stainless-steel powder for weight, glass fibre for stiffness, and a polymer resin binder. A brass nut fastener secures the comfortably shaped hardwood handle. The saw has great balance it cuts easily, stays true and the pistol grip helps make the saw feel like an extension of your arm. Overall length 360mm (14.1\/4\u003cspecial id=\"1\"\u003e\u003c\/special\u003e)\u003c\/p\u003e","brand":"Veritas","offers":[{"title":"Default Title","offer_id":54116667982171,"sku":"211803","price":80.98,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/211803_xl.jpg?v=1789762056","url":"https:\/\/www.axminstertools.com\/products\/veritas-small-crosscut-saw-16tpi-235mm","provider":"Axminster Tools","version":"1.0","type":"link"}
