Made from aluminium alloy with brass fittings, the Transfer Scribe comes with a double ended steel guide pin. The pin has a pointed end for compass work and a rounded curved end for smooth scribing. The pin can be replaced with a pencil for double scribing. Fully adjustable from 0-300mm. Bi-directional level bubbles help guide the user and ensure the scribe is as accurate as possible. Any standard pencil can be used, the Transfer is supplied with an indelible pencil that marks well with only light pressure.
Web Attribute Set Compasses, Dividers & Calipers
