The Vitrex Torque Master Power Tile Cutter is capable of cutting ceramic and porcelain, wall and floor tiles. The continuous rim diamond cutting blade ensures a clean cut. Its 450W Hi-Torque geared motor gives maximum cutting performance. The blade is water cooled for dust free cutting and fitted with an adjustable height splash guard. The splash guard has a quick release for plunge cuts. The water is continuously recirculated keeping the blade cool throughout the cut. A straight fence is provided along with an adjustable mitre fence for angle cuts from 0
Vitrex
Vitrex Torque Master Power Tile Cutter 450W 230V
| Max Depth of Cut @ 45º | 17 mm |
| Max Depth of Cut @ 90º | 25 mm |
| Overall L x W x H | 375 mm x 365 mm x 180 mm |
| Power | 450 W |
| Rating | Home Workshop |
| Table Size | 375 mm x 365 mm |
| Blade Diameter | 110 mm |
| Web Attribute Set | Tile Cutting Machines |
| EAN Barcode | 5011204603749 |
