Wataoka Wood Pro 170mm Flat File is a Japanese-made woodworking file designed for shaping, smoothing and refining timber surfaces. Combining traditional file-making expertise with modern manufacturing techniques, it features a flat profile and double-sided cutting surfaces for versatile workshop use. With a 170mm working length, 200mm overall length and 20mm width, it offers a good balance of control, reach and efficient material removal.
The Wood Pro tooth pattern provides a positive cutting action with effective chip clearance, helping to reduce clogging and maintain a consistent cut. For best results, use light pressure and maintain contact with the workpiece on the return stroke to help reduce the accumulation of cutting dust on the file.
Featuring a 170mm working length, 200mm overall length, 20mm width and approximately 5mm thickness, this file is well suited to levelling, smoothing and refining flat surfaces. The finish achieved is comparable to approximately 280 grit abrasive, making it suitable for final shaping and surface preparation prior to finishing.
Wataoka is a long-established Japanese file manufacturer based in Hiroshima, with a reputation for producing high-quality files that combine traditional craftsmanship with practical performance.
Ideal for furniture makers, joiners, luthiers and general woodworkers, the Wataoka Wood Pro 170mm Flat File is an excellent choice for shaping and refining timber with accuracy and control. Supplied as an individual file with tang.
Web Attribute Set Carving Knives, Scrapers & Chip Carving
EAN Barcode 5052511144372
