WATAOKA
Wataoka Wood Pro 90mm Half Round File
SKU: 113768
€20,00 €23,00 Save €3,00
  • Japanese-made woodworking file
  • 90mm working length
  • Half round profile
  • Suitable for shaping curves and contours
  • Efficient chip clearance
  • Produces a smooth surface finish
  • Suitable for wood, bamboo, resins, MDF and plywood
  • Textured synthetic handle
Wataoka Wood Pro 90mm Half Round File is a Japanese-made woodworking rasp designed for detailed shaping, carving and surface refinement. Featuring a half round profile, it is particularly effective for working on curves, contours and sculpted forms whilst still being capable of refining flat surfaces. With a 90mm working length, 200mm overall length and 15mm width, it offers excellent control for intricate woodworking and carving applications.
The precision-cut tooth pattern combines efficient material removal with a smooth cutting action, producing fine shavings rather than coarse dust. Diagonal chip clearance grooves help reduce clogging and maintain a consistent cut, whilst the compact, lightweight design makes the file easy to manoeuvre during detailed work. For best results, use light pressure and maintain contact with the workpiece on the return stroke to help reduce the accumulation of cutting dust on the file.
Featuring a 90mm working length, 200mm overall length and 15mm width, this file is suitable for shaping wood, bamboo, resins, plastics, MDF and plywood. The half round profile makes it especially useful for refining internal curves, shaping contours and carrying out detailed sculpting work. A textured synthetic handle provides a comfortable, secure grip during use.
Wataoka is a long-established Japanese file manufacturer based in Hiroshima, with a reputation for producing high-quality files that combine traditional craftsmanship with practical performance.
Ideal for woodcarvers, furniture makers, luthiers, toy makers and model makers, the Wataoka Wood Pro 90mm Half Round File is an excellent choice for detailed shaping and fine finishing work where control and surface quality are important.
Web Attribute Set Carving Knives, Scrapers & Chip Carving
EAN Barcode 5052511144341
