{"product_id":"wd-40-r-high-performance-silicone-lubricant-400ml","title":"WD‑40® High Performance Silicone Lubricant 400ml","description":"\u003cp\u003eWD‑40 Specialist High Performance Silicone Lubricant delivers superior protection against moisture and extreme temperatures, performing reliably from ‑35°C to +200°C. Its clean, non‑staining formula prevents sticking and bonding while guarding surfaces against rust and corrosion. Safe for use on plastic, rubber, wood, and metal, it provides smooth, long‑lasting lubrication across a wide range of applications. The nozzle on the can allows for a wide spray, narrow straw spray and can be used up to 360 degrees in rotation.\u003c\/p\u003e","brand":"WD-40","offers":[{"title":"Default Title","offer_id":54118852264283,"sku":"114272","price":9.5,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/114272_xl.jpg?v=1789793960","url":"https:\/\/www.axminstertools.com\/products\/wd-40-r-high-performance-silicone-lubricant-400ml","provider":"Axminster Tools","version":"1.0","type":"link"}
