WD‑40® needs no introduction; in all probability a can of WD‑40® will be sitting somewhere in practically every workshop in the land. This all-purpose liquid has so many uses, it is almost indispensable. Although not essentially a lubricant, WD‑40® will lubricate all light machinery and electrical equipment. It protects metal from rust and corrosion, penetrates stuck or jammed parts, displaces moisture and lubricates just about anything. It is also great when it comes to cleaning grease, grime and other marks from most surfaces.
With its flexible straw, this aerosol provides access to the most difficult spots that require a precise application. The ingenious 180mm long flexible straw allows you to pinpoint precisely where you apply the WD‑40®, the straw maintains its position and folds neatly when not in use.
Supplied in 400ml spray can.
Web Attribute Set Lubricants & Cleaners
EAN Barcode 5032227446885
