WD‑40 Smart Straw is the versatile solution for protecting, cleaning and lubricating a huge range of items. It stops squeaks, drives out moisture, loosens stuck or rusted parts, and helps keep mechanisms running smoothly. The Smart Straw design lets you switch instantly between a precise, targeted stream and a wider spra-simply flip the straw up for accuracy or down for regular coverage. Supplied in a 500ml can.
WD-40
WD‑40® Multi Use with Smart Straw 500ml
| Web Attribute Set | Lubricants & Cleaners |
| EAN Barcode | 5032227440371 |
