{"product_id":"woodcut-tools-stem-sharpener","title":"Woodcut Tools Stem Sharpener","description":"\u003cp\u003eThe Tru-Grind Stem sharpener is uniquely designed to hold flat scrapers and circular cup cutters up to 25mm for sharpening. It is designed to be used with the Woodcut Tools Tru-Grind and other similar sharpening systems. Simply screw your cutter upside down onto the head of the Stem Sharpener using the supplied hex key. Either use in conjunction with your Sharpening System, in your lathe pin jaws or cordless drill chuck. Sharpen safely with the Stem Sharpener. You can keep your fingers well clear, which can be an issue when trying to traditionally sharpen your smaller cutters. Easy to use, it only requires minimal pressure to completely restore an edge.\u003c\/p\u003e","brand":"Woodcut","offers":[{"title":"Default Title","offer_id":54118379782491,"sku":"106363","price":14.0,"currency_code":"EUR","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/106363_xl.jpg?v=1789777471","url":"https:\/\/www.axminstertools.com\/products\/woodcut-tools-stem-sharpener","provider":"Axminster Tools","version":"1.0","type":"link"}
