The Woodpeckers 12-IN-1 Tool Metric combines 12 useful measuring and marking functions in one compact layout tool. Based on a classic tool first developed in the 1920s, its two adjustable scales can be positioned in different configurations to tackle a wide range of everyday furniture making, cabinetmaking and workshop layout tasks.
The versatile design functions as a rule, T-square, try square, bevel gauge, compass, marking gauge, divider, depth gauge, diameter gauge, protractor, mitre square and inside measuring scale. Precision-machined grooves locate the adjustable scale square to the base for different functions, while a scribing guide allows you to mark lines parallel to the edge of your workpiece.
The stainless steel scales have a satin, non-glare finish with clear laser-engraved metric graduations. Angle guides for 30°, 45° and 60° make commonly used angles quick to set, while the bevel gauge function can be used to transfer other angles. The adjustable design also allows inside measurements to be checked and arcs to be marked using the tool as a beam compass.
Woodpeckers is known for precision woodworking tools, measuring equipment and workshop accessories designed to improve accuracy and repeatability. Their tools are precision machined and carefully inspected in Ohio, USA.
Ideal for furniture makers, cabinetmakers and woodworkers who want to keep a versatile measuring and layout tool close to hand, the 12-IN-1 combines multiple commonly used functions in one compact design.
Web Attribute Set Laying Out Tools
EAN Barcode 0810137208091
