{"product_id":"woodpecker-3d-multi-marking-square-metric","title":"Woodpecker 3D Multi-Marking Square Metric","description":"\u003cp\u003eThe Woodpeckers 3D Multi-Marking Square Metric is a versatile precision tool for marking across both the face and edge of a workpiece, helping you lay out accurate joinery without repeatedly repositioning your square. Its three-dimensional design also provides a stable reference for checking assemblies and setting up woodworking machinery.\u003c\/p\u003e\u003cp\u003eTwo full-length legs allow layout lines to be carried accurately between adjacent faces, while precision-milled steps provide quick reference points for common dimensions. The wide base and extended legs offer excellent stability, including on thinner stock, and can register against both inside and outside corners. A central groove in the base also creates equal shoulders for laying out centred mortise and tenon cheeks.\u003c\/p\u003e\u003cp\u003ePrecision milled from solid aluminium, the square stands 114.3mm (4-1\/2\u003cspecial id=\"32\"\u003e\u003c\/special\u003e) high, providing a perpendicular reference for setting saw blades, router cutters, drill bits and machine tables. Clear laser-engraved metric scales aid height adjustment, while the substantial blade provides a reliable reference during machine setup.\u003c\/p\u003e\u003cp\u003eWoodpeckers is known for precision woodworking tools, measuring equipment and workshop accessories designed to improve accuracy and repeatability. Their tools are precision machined and carefully inspected in Ohio, USA.\u003c\/p\u003e\u003cp\u003eIdeal for furniture makers, cabinetmakers and joiners, the 3D Multi-Marking Square combines joinery layout, squaring and machinery setup in one compact tool. Supplied: One Woodpeckers 3D Multi-Marking Square in metric.\u003c\/p\u003e","brand":"Woodpeckers","offers":[{"title":"Default Title","offer_id":55036457550171,"sku":"114834","price":89.98,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/114834_xl.jpg?v=1793618494","url":"https:\/\/www.axminstertools.com\/products\/woodpecker-3d-multi-marking-square-metric","provider":"Axminster Tools","version":"1.0","type":"link"}
