The Woodpeckers Box Clamp M2 is designed to hold box, cabinet and frame assemblies securely at 90°, helping keep components square during assembly, dry fitting, layout work and fastening. The open design provides excellent access to the joint, making it easier to install screws, nails and other fixings without the clamp getting in the way.
A low-profile wedge mechanism applies equal pressure to both workpieces, drawing them into square alignment as the clamp is tightened. The design can accommodate material thickness variations of up to 6.35mm (1/4
Suitable for material from 6.35mm (1/4
Woodpeckers is known for precision woodworking tools, measuring equipment and workshop accessories designed to improve accuracy and repeatability. Their tools are precision machined and carefully inspected in Ohio, USA.
Ideal for furniture makers, cabinetmakers and woodworkers assembling boxes, drawers, cabinets and carcasses, the Box Clamp M2 helps maintain accurate 90° alignment while leaving the joint fully accessible. Supplied with: two Woodpeckers Box Clamp M2 clamps, two knobs and two hex-head bolts.
