{"product_id":"woodpecker-box-clamp-m2-pair","title":"Woodpeckers Box Clamp M2 (Pair)","description":"\u003cp\u003eThe Woodpeckers Box Clamp M2 is designed to hold box, cabinet and frame assemblies securely at 90°, helping keep components square during assembly, dry fitting, layout work and fastening. The open design provides excellent access to the joint, making it easier to install screws, nails and other fixings without the clamp getting in the way.\u003c\/p\u003e\u003cp\u003eA low-profile wedge mechanism applies equal pressure to both workpieces, drawing them into square alignment as the clamp is tightened. The design can accommodate material thickness variations of up to 6.35mm (1\/4\u003cspecial id=\"32\"\u003e\u003c\/special\u003e), helping maintain accurate alignment even when the two components are not identical in thickness.\u003c\/p\u003e\u003cp\u003eSuitable for material from 6.35mm (1\/4\u003cspecial id=\"32\"\u003e\u003c\/special\u003e) to 25.4mm (1\u003cspecial id=\"32\"\u003e\u003c\/special\u003e) thick, the Box Clamp M2 can be used with butt joints, mitres, housings, rebates, T-joints, dovetails and box joints. Each clamp can be configured either for bench mounting or hand-held use by changing the supplied fixing hardware, allowing it to be adapted to different assembly tasks.\u003c\/p\u003e\u003cp\u003eWoodpeckers is known for precision woodworking tools, measuring equipment and workshop accessories designed to improve accuracy and repeatability. Their tools are precision machined and carefully inspected in Ohio, USA.\u003c\/p\u003e\u003cp\u003eIdeal for furniture makers, cabinetmakers and woodworkers assembling boxes, drawers, cabinets and carcasses, the Box Clamp M2 helps maintain accurate 90° alignment while leaving the joint fully accessible. Supplied with: two Woodpeckers Box Clamp M2 clamps, two knobs and two hex-head bolts.\u003c\/p\u003e","brand":"Woodpeckers","offers":[{"title":"Default Title","offer_id":55036458565979,"sku":"114828","price":50.98,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/114828_xl.jpg?v=1793618494","url":"https:\/\/www.axminstertools.com\/products\/woodpecker-box-clamp-m2-pair","provider":"Axminster Tools","version":"1.0","type":"link"}
