{"product_id":"woodpecker-clamp-n-guide-48-capacity","title":"Woodpeckers Clamp-N-Guide 48\" Capacity","description":"\u003cp\u003eThe Woodpeckers Clamp-N-Guide 48\u003cspecial id=\"32\"\u003e\u003c\/special\u003e Capacity combines a straightedge guide and clamp in one versatile tool for routing, circular sawing, layout and assembly work. With a 1,219mm (48\u003cspecial id=\"32\"\u003e\u003c\/special\u003e) clamping capacity, it provides a secure, straight reference across larger workpieces and sheet material while its low-friction anodised surface allows tools to travel smoothly along the guide.\u003c\/p\u003e\u003cp\u003eA large clamping handle provides good leverage, while the knurled steel clamp rod helps maintain a secure grip on the workpiece. Used as a straightedge, the Clamp-N-Guide provides a reliable reference for guiding a circular saw when breaking down sheet material. It can also be used as an assembly clamp, making it a particularly versatile addition to the workshop.\u003c\/p\u003e\u003cp\u003eFor routing applications, the compatible Clamp-N-Guide Router Adapter locks onto the guide while allowing the router base to remain flat on the workpiece. Router compatibility is determined by the guide rod holes in the router base, with compatible rod sizes of 6mm (1\/4\u003cspecial id=\"32\"\u003e\u003c\/special\u003e), 8mm (5\/16\u003cspecial id=\"32\"\u003e\u003c\/special\u003e), 9.5mm (3\/8\u003cspecial id=\"32\"\u003e\u003c\/special\u003e) and 10mm (25\/64\u003cspecial id=\"32\"\u003e\u003c\/special\u003e). The Router Adapter and appropriate guide rods are available separately.\u003c\/p\u003e\u003cp\u003eWoodpeckers is known for precision woodworking tools, measuring equipment and workshop accessories designed to improve accuracy, versatility and repeatability. Their tools are precision machined and carefully inspected in Ohio, USA.\u003c\/p\u003e\u003cp\u003eIdeal for routing, guiding a circular saw, breaking down sheet material and general assembly work, the Woodpeckers Clamp-N-Guide provides a straight reference and secure clamping in one convenient tool. Supplied: one Clamp-N-Guide with 48\u003cspecial id=\"32\"\u003e\u003c\/special\u003e Capacity.\u003c\/p\u003e","brand":"Woodpeckers","offers":[{"title":"Default Title","offer_id":55036458598747,"sku":"114824","price":89.98,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/114824_xl.jpg?v=1793618493","url":"https:\/\/www.axminstertools.com\/products\/woodpecker-clamp-n-guide-48-capacity","provider":"Axminster Tools","version":"1.0","type":"link"}
