The Woodpeckers Edge Rule Stop is a dedicated replacement or additional stop for the Woodpeckers Woodworkers Edge Rule, designed to make repetitive measuring and marking quicker and more consistent. It slides along the Edge Rule and locks at your chosen measurement, helping you reproduce the same setting accurately across multiple workpieces.
Ideal for repetitive workshop tasks, the stop eliminates the need to find and reset the same measurement each time. Simply position it at the required measurement and lock it in place, creating a reliable reference point for repeat marking. Keeping an additional stop to hand can also be useful when working with regularly used dimensions.
Designed specifically for the Woodpeckers Woodworkers Edge Rule system, the Edge Rule Stop provides a secure, adjustable position along the rule and is intended exclusively for use with compatible Woodpeckers Edge Rules.
Woodpeckers is known for precision woodworking tools, measuring equipment and workshop accessories designed with accuracy and ease of use at their core, making its tools particularly popular for furniture making, cabinetry and other precision woodworking applications.
A useful addition for anyone regularly using a Woodpeckers Woodworkers Edge Rule, this individual stop is ideal as a replacement or spare and is particularly useful for repetitive marking tasks where consistency matters. Compatible with Woodpeckers Woodworkers Edge Rules only.
Web Attribute Set Rules
EAN Barcode 0602573564950
