{"product_id":"woodpecker-indexable-mitre-gauge-includes-flip-stop","title":"Woodpeckers Indexable Mitre Gauge Includes Flip Stop","description":"\u003cp\u003eThe Woodpeckers Indexable Mitre Gauge with Flip Stop provides accurate angle setting and repeatable length control for crosscutting and mitre work on the table saw. Combining a self-adjusting mitre bar, indexed angle settings and an extendable graduated fence, it offers a versatile upgrade over a standard table saw mitre gauge.\u003c\/p\u003e\u003cp\u003eThe patented mitre bar uses four leaf springs to maintain consistent contact with the sides of the mitre slot, compensating for slight variations or wear. It is designed for nominal 19.1mm x 9.5mm (3\/4\u003cspecial id=\"32\"\u003e\u003c\/special\u003e x 3\/8\u003cspecial id=\"32\"\u003e\u003c\/special\u003e) mitre slots, while removable T-slot retainers provide additional support on compatible saws. Precision-machined indexing positions make common angles quick to set, with a clear hairline reticle for accurately setting other angles.\u003c\/p\u003e\u003cp\u003eThe graduated fence provides up to 457mm (18\u003cspecial id=\"32\"\u003e\u003c\/special\u003e) capacity when closed and extends to 787mm (31\u003cspecial id=\"32\"\u003e\u003c\/special\u003e). The tool-free, micro-adjustable flip stop can be positioned for accurate, repeatable cuts, while graduations on the extension allow measurements to be set even when the fence is extended. A sacrificial end block helps support the workpiece at the cut and reduce breakout.\u003c\/p\u003e\u003cp\u003eWoodpeckers is known for precision woodworking tools, measuring equipment and workshop accessories designed to improve accuracy and repeatability. Their tools are precision machined and carefully inspected in Ohio, USA.\u003c\/p\u003e\u003cp\u003eIdeal for furniture makers, cabinetmakers and woodworkers carrying out accurate crosscuts, mitres and repetitive cutting, the Woodpeckers Indexable Mitre Gauge combines precise angle adjustment with excellent length control. Supplied with: Woodpeckers Indexable Mitre Gauge, extendable fence, micro-adjustable flip stop, sacrificial end block and T-slot retainers.\u003c\/p\u003e","brand":"Woodpeckers","offers":[{"title":"Default Title","offer_id":55036477342043,"sku":"114825","price":229.98,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/114825_xl.jpg?v=1793618494","url":"https:\/\/www.axminstertools.com\/products\/woodpecker-indexable-mitre-gauge-includes-flip-stop","provider":"Axminster Tools","version":"1.0","type":"link"}
