The Woodpeckers Indexable Mitre Gauge with Flip Stop provides accurate angle setting and repeatable length control for crosscutting and mitre work on the table saw. Combining a self-adjusting mitre bar, indexed angle settings and an extendable graduated fence, it offers a versatile upgrade over a standard table saw mitre gauge.
The patented mitre bar uses four leaf springs to maintain consistent contact with the sides of the mitre slot, compensating for slight variations or wear. It is designed for nominal 19.1mm x 9.5mm (3/4 x 3/8) mitre slots, while removable T-slot retainers provide additional support on compatible saws. Precision-machined indexing positions make common angles quick to set, with a clear hairline reticle for accurately setting other angles.
The graduated fence provides up to 457mm (18) capacity when closed and extends to 787mm (31). The tool-free, micro-adjustable flip stop can be positioned for accurate, repeatable cuts, while graduations on the extension allow measurements to be set even when the fence is extended. A sacrificial end block helps support the workpiece at the cut and reduce breakout.
Woodpeckers is known for precision woodworking tools, measuring equipment and workshop accessories designed to improve accuracy and repeatability. Their tools are precision machined and carefully inspected in Ohio, USA.
Ideal for furniture makers, cabinetmakers and woodworkers carrying out accurate crosscuts, mitres and repetitive cutting, the Woodpeckers Indexable Mitre Gauge combines precise angle adjustment with excellent length control. Supplied with: Woodpeckers Indexable Mitre Gauge, extendable fence, micro-adjustable flip stop, sacrificial end block and T-slot retainers.
Web Attribute Set Saw Bench Accessories
EAN Barcode 0810137207117
