{"product_id":"woodpecker-iron-grip-small-parts-holder","title":"Woodpeckers Iron-Grip Small Parts Holder","description":"\u003cp\u003eThe Woodpeckers Iron-Grip Small Parts Holder provides a secure, controlled way to hold small workpieces when machining on a router table. Substantial jaws and a heavy-duty clamping screw grip the work securely while keeping your hands away from the cutter, helping improve both accuracy and control when routing small components.\u003c\/p\u003e\u003cp\u003eThe Iron-Grip accommodates workpieces up to 266.7mm (10-1\/2\u003cspecial id=\"32\"\u003e\u003c\/special\u003e), while components as small as approximately 19.1 x 19.1mm (3\/4\u003cspecial id=\"32\"\u003e\u003c\/special\u003e x 3\/4\u003cspecial id=\"32\"\u003e\u003c\/special\u003e) can be securely held, depending on the router cutter profile. Adjustable stop pins provide repeatable workpiece positioning, with five mounting positions ranging from 12.7mm (1\/2\u003cspecial id=\"32\"\u003e\u003c\/special\u003e) to 95.3mm (3-3\/4\u003cspecial id=\"32\"\u003e\u003c\/special\u003e) from the edge.\u003c\/p\u003e\u003cp\u003eFor use with non-bearing-guided cutters, the fence guide runs against the router table fence to guide the workpiece consistently through the cut. The standard fence guide accommodates cutting depths up to 38.1mm (1-1\/2\u003cspecial id=\"32\"\u003e\u003c\/special\u003e), making the Iron-Grip suitable for cutting grooves, housings, rebates, tenons and half-lap joints as well as profile routing. Stop pins also make repeat operations easier when machining multiple matching components.\u003c\/p\u003e\u003cp\u003eWoodpeckers is known for precision woodworking tools, measuring equipment and workshop accessories designed to improve accuracy and repeatability. Their tools are precision machined and carefully inspected in Ohio, USA.\u003c\/p\u003e\u003cp\u003eIdeal for box making, furniture making and other projects involving smaller components, the Iron-Grip provides secure workholding while keeping hands safely away from the router cutter. Supplied with: Woodpeckers Iron-Grip Small Parts Holder, fence guide and stop pins.\u003c\/p\u003e","brand":"Woodpeckers","offers":[{"title":"Default Title","offer_id":55036477407579,"sku":"114826","price":213.98,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/114826_xl.jpg?v=1793618494","url":"https:\/\/www.axminstertools.com\/products\/woodpecker-iron-grip-small-parts-holder","provider":"Axminster Tools","version":"1.0","type":"link"}
