The Woodpeckers StabilMax Trim Router Offset Base gives your trim router a larger, more stable footprint for greater control when routing edges, corners and narrow sections. Its extended teardrop-shaped base and large handle provide additional support, helping keep the router upright and reducing the tendency to tip as you work around a workpiece.
The extended section of the base provides extra leverage and support when much of the router would otherwise be unsupported, particularly when routing square corners. This makes the StabilMax ideal for edge profiling, flush trimming and other operations where the compact base of a trim router can make maintaining consistent contact difficult.
Precision machined from solid phenolic, the StabilMax is pre-drilled to fit a wide range of popular corded and cordless trim routers from Bosch, DeWalt, Makita, Milwaukee, Porter-Cable, Ridgid and Ryobi. The base also accepts compatible Porter-Cable-style template guide bushes, extending its usefulness to template routing applications. An included centring pin allows the guide bush to be accurately aligned with the router collet.
Woodpeckers is known for precision woodworking tools, measuring equipment and workshop accessories designed to improve accuracy and repeatability. Their tools are precision machined and carefully inspected in Ohio, USA.
Ideal for furniture makers, cabinetmakers and woodworkers looking for greater stability and control from a compact router, the StabilMax is particularly useful for edge profiling, template routing and working around corners. Check router compatibility before purchase. Supplied with: Woodpeckers StabilMax Trim Router Offset Base and centring pin.
