The Woodpeckers Precision T-Square 600mm makes accurate measuring, marking and striking parallel lines across larger workpieces and sheet material quick and straightforward. Its precision-machined beam registers securely against the edge of your workpiece, while the long 600mm blade provides excellent reach for cabinetmaking, furniture making and larger layout tasks.
Precision-machined support lips on the beam help keep the T-square securely registered against the workpiece and prevent it from tipping or rolling while marking. Integrated scribing guides run along the blade, allowing you to position a suitable pencil or marking tool and slide the square along the workpiece to create consistently parallel lines. Additional holes provide a convenient guide for laying out shelf pin positions.
The aluminium blade is secured to the precision-machined beam under constant tension, providing an angular accuracy of ±0.02° (0.004
Woodpeckers is known for precision woodworking tools, measuring equipment and workshop accessories designed for accurate and repeatable work. Its tools are precision machined and carefully inspected in Ohio, USA.
Ideal for cabinetmakers, furniture makers and woodworkers working with sheet materials, larger cabinet components, bookcases and similar projects, the Woodpeckers Precision T-Square 600mm combines accurate squaring, measuring and parallel marking in one versatile layout tool. Supplied with: 600mm T-Square and wall-mountable Rack-It for convenient workshop storage.
