{"product_id":"woodpecker-thin-rip-guide","title":"Woodpeckers Thin Rip Guide","description":"\u003cp\u003eThe Woodpeckers Thin Rip Guide makes it easy to produce consistently sized thin strips on your table saw while keeping the cut piece on the offcut side of the blade. This avoids trapping thin material between the blade and rip fence, providing a more controlled approach to repetitive thin ripping for projects such as Kumiko, inlay work and cutting boards.\u003c\/p\u003e\u003cp\u003eThe guide fits into a compatible T-slot mitre slot and is positioned ahead of the saw blade. Set the required strip thickness using the laser-engraved scale, adjust the rip fence until the workpiece touches the guide bearings and make the cut. Reposition the fence for each subsequent cut to produce repeatable strips without relying on the rip fence to set the finished strip thickness.\u003c\/p\u003e\u003cp\u003eDesigned for 19.1mm x 9.5mm (3\/4\u003cspecial id=\"32\"\u003e\u003c\/special\u003e x 3\/8\u003cspecial id=\"32\"\u003e\u003c\/special\u003e) T-slot mitre slots, the Thin Rip Guide can produce strips from approximately 0.8mm (1\/32\u003cspecial id=\"32\"\u003e\u003c\/special\u003e) up to 31.8mm (1-1\/4\u003cspecial id=\"32\"\u003e\u003c\/special\u003e), depending on the saw and material. Metric and imperial scales are laser engraved into the anodised aluminium body and can be calibrated to the saw blade, allowing strip thickness to be set without compensating for the blade kerf.\u003c\/p\u003e\u003cp\u003eWoodpeckers is known for precision woodworking tools, measuring equipment and workshop accessories designed to improve accuracy and repeatability. Their tools are precision machined and carefully inspected in the USA.\u003c\/p\u003e\u003cp\u003eIdeal for Kumiko, decorative inlays, cutting boards and other projects requiring multiple thin strips of consistent thickness, the Woodpeckers Thin Rip Guide provides a simple and repeatable setup for accurate thin ripping. Supplied with: Woodpeckers Thin Rip Guide and wall-mountable Rack-It.\u003c\/p\u003e","brand":"Woodpeckers","offers":[{"title":"Default Title","offer_id":55036592488795,"sku":"114835","price":223.98,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/114835_xl.jpg?v=1793618494","url":"https:\/\/www.axminstertools.com\/products\/woodpecker-thin-rip-guide","provider":"Axminster Tools","version":"1.0","type":"link"}
