{"product_id":"woodpecker-variable-pressure-featherboards-pair","title":"Woodpeckers Variable Pressure Featherboards (Pair)","description":"\u003cp\u003eThe Woodpeckers Variable Pressure Featherboards provide controlled, adjustable pressure to help keep your workpiece securely positioned when routing, ripping, shaping or resawing. Supplied as a pair, they help maintain consistent contact with the fence or table as material is fed through the cut.\u003c\/p\u003e\u003cp\u003eUnlike conventional featherboards that need repositioning to alter the holding pressure, Woodpeckers use a built-in adjustment plate. This allows you to increase or decrease pressure without moving the featherboard itself, making setup quicker and easier while maintaining the position you have already established.\u003c\/p\u003e\u003cp\u003eDesigned for use with compatible 6.35mm (1\/4\u003cspecial id=\"32\"\u003e\u003c\/special\u003e) T-tracks, the featherboards attach using the included mounting hardware. Optional hardware is available separately for use with standard 19.1mm x 9.5mm (3\/4\u003cspecial id=\"32\"\u003e\u003c\/special\u003e x 3\/8\u003cspecial id=\"32\"\u003e\u003c\/special\u003e) mitre slots. For Incra fences, they are recommended for use with the Hi-Rise Fence Cap only.\u003c\/p\u003e\u003cp\u003eWoodpeckers is known for precision woodworking tools, measuring equipment and workshop accessories designed to improve accuracy and repeatability. Their Variable Pressure Featherboards are made in the USA.\u003c\/p\u003e\u003cp\u003eIdeal for table saws, router tables and other suitable woodworking setups where controlled workpiece support is required, the variable-pressure design makes fine-tuning the setup simple without repeatedly repositioning the featherboards. Supplied with: two Featherboards and T-track mounting hardware.\u003c\/p\u003e","brand":"Woodpeckers","offers":[{"title":"Default Title","offer_id":55036593111387,"sku":"114820","price":44.98,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/114820_xl.jpg?v=1793618494","url":"https:\/\/www.axminstertools.com\/products\/woodpecker-variable-pressure-featherboards-pair","provider":"Axminster Tools","version":"1.0","type":"link"}
