The Woodpeckers 25.5 Mitre Bar provides a reliable foundation for building accurate crosscut sleds, table saw jigs and workshop fixtures. Designed to eliminate the common fitting issues associated with mitre slots, it uses an innovative self-adjusting system to maintain a smooth, consistent fit in a wide range of table saws.
Five specially engineered nylon leaf springs are built into the edge of the bar, automatically expanding or contracting to compensate for undersized, oversized or worn mitre slots. This design helps maintain consistent contact against the mitre slot wall without requiring manual adjustment, even where slot dimensions vary along their length.
Measuring 648mm (25.5) long, the Mitre Bar provides excellent support for larger sleds and jigs, helping improve stability and accuracy. Two removable stainless steel T-washers provide additional support in T-track mitre slots and can be removed for use in standard 19.1mm x 9.5mm (3/4 x 3/8) slots. Seven threaded mounting points for 10-32 machine screws make attaching custom sleds, fixtures and platforms straightforward.
Woodpeckers is known for precision woodworking tools, measuring equipment and workshop accessories designed to improve accuracy and repeatability. Their tools are precision machined and carefully inspected in Ohio, USA.
Ideal for woodworkers building custom crosscut sleds, mitre jigs and workshop fixtures, the Woodpeckers 25.5 Mitre Bar offers smooth operation, excellent support and a self-adjusting fit for a wide range of table saws. Supplied with: Woodpeckers 25.5 Mitre Bar, T-washers and mounting screws.
Web Attribute Set Routing Jig Accessories
EAN Barcode 810018204563
