{"product_id":"woodpeckers-25-5-mitre-bar","title":"Woodpeckers 25.5 Mitre Bar","description":"\u003cp\u003eThe Woodpeckers 25.5\u003cspecial id=\"32\"\u003e\u003c\/special\u003e Mitre Bar provides a reliable foundation for building accurate crosscut sleds, table saw jigs and workshop fixtures. Designed to eliminate the common fitting issues associated with mitre slots, it uses an innovative self-adjusting system to maintain a smooth, consistent fit in a wide range of table saws.\u003c\/p\u003e\u003cp\u003eFive specially engineered nylon leaf springs are built into the edge of the bar, automatically expanding or contracting to compensate for undersized, oversized or worn mitre slots. This design helps maintain consistent contact against the mitre slot wall without requiring manual adjustment, even where slot dimensions vary along their length.\u003c\/p\u003e\u003cp\u003eMeasuring 648mm (25.5\u003cspecial id=\"32\"\u003e\u003c\/special\u003e) long, the Mitre Bar provides excellent support for larger sleds and jigs, helping improve stability and accuracy. Two removable stainless steel T-washers provide additional support in T-track mitre slots and can be removed for use in standard 19.1mm x 9.5mm (3\/4\u003cspecial id=\"32\"\u003e\u003c\/special\u003e x 3\/8\u003cspecial id=\"32\"\u003e\u003c\/special\u003e) slots. Seven threaded mounting points for 10-32 machine screws make attaching custom sleds, fixtures and platforms straightforward.\u003c\/p\u003e\u003cp\u003eWoodpeckers is known for precision woodworking tools, measuring equipment and workshop accessories designed to improve accuracy and repeatability. Their tools are precision machined and carefully inspected in Ohio, USA.\u003c\/p\u003e\u003cp\u003eIdeal for woodworkers building custom crosscut sleds, mitre jigs and workshop fixtures, the Woodpeckers 25.5\u003cspecial id=\"32\"\u003e\u003c\/special\u003e Mitre Bar offers smooth operation, excellent support and a self-adjusting fit for a wide range of table saws. Supplied with: Woodpeckers 25.5\u003cspecial id=\"32\"\u003e\u003c\/special\u003e Mitre Bar, T-washers and mounting screws.\u003c\/p\u003e","brand":"Woodpeckers","offers":[{"title":"Default Title","offer_id":55036477702491,"sku":"114851","price":89.98,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/114851_xl.jpg?v=1793618494","url":"https:\/\/www.axminstertools.com\/products\/woodpeckers-25-5-mitre-bar","provider":"Axminster Tools","version":"1.0","type":"link"}
