{"product_id":"woodpeckers-3d-setup-blocks-7-piece-set","title":"Woodpeckers 3D Setup Blocks 7 Piece Set","description":"\u003cp\u003eThe Woodpeckers 3D Setup Blocks 7 Piece Set provides seven precision-machined blocks for quickly setting and checking common dimensions and angles on workshop machinery. Each block offers four different reference points for its stated dimension, making the set particularly versatile for setting saw blades, router cutters, fences and drill press depths.\u003c\/p\u003e\u003cp\u003eEach block can be used by its overall thickness, centre cut-out, stepped shoulder or raised top section. The different reference surfaces make it easy to set cutter and blade heights, position fences, check groove and housing depths or gauge material thickness. The centre cut-out is particularly useful for positioning around a cutter, while the stepped shoulder provides a convenient reference between a cutting tool and fence or table.\u003c\/p\u003e\u003cp\u003eThe seven blocks cover 3.2mm (1\/8\u003cspecial id=\"32\"\u003e\u003c\/special\u003e), 4.8mm (3\/16\u003cspecial id=\"32\"\u003e\u003c\/special\u003e), 6.35mm (1\/4\u003cspecial id=\"32\"\u003e\u003c\/special\u003e), 7.9mm (5\/16\u003cspecial id=\"32\"\u003e\u003c\/special\u003e), 9.5mm (3\/8\u003cspecial id=\"32\"\u003e\u003c\/special\u003e), 11.1mm (7\/16\u003cspecial id=\"32\"\u003e\u003c\/special\u003e) and 12.7mm (1\/2\u003cspecial id=\"32\"\u003e\u003c\/special\u003e). Each also incorporates a different bevel angle, providing 30°, 45°, 60°, 70°, 80°, 85° and 90° references for setting table saw blades, mitre saws and other machinery.\u003c\/p\u003e\u003cp\u003eWoodpeckers is known for precision woodworking tools, measuring equipment and workshop accessories designed to improve accuracy and repeatability. Their tools are precision machined and carefully inspected in Strongsville, Ohio, USA.\u003c\/p\u003e\u003cp\u003eIdeal for furniture makers, cabinetmakers and woodworkers who regularly set up saws, routers and other workshop machinery, these blocks provide quick physical references without repeatedly reaching for a rule or measuring gauge. Supplied with: seven Woodpeckers 3D Setup Blocks and wall-mountable Rack-It.\u003c\/p\u003e","brand":"Woodpeckers","offers":[{"title":"Default Title","offer_id":55036479766875,"sku":"114864","price":184.98,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/114864_xl.jpg?v=1793618596","url":"https:\/\/www.axminstertools.com\/products\/woodpeckers-3d-setup-blocks-7-piece-set","provider":"Axminster Tools","version":"1.0","type":"link"}
